Has anyone found the wire that’s in the cab that you can use for the high beams?
Bc the wires the the head lights won’t work it’s something to do with the ground . I wish it was that easy. I think you have to grab it at the relay down at the kick panelBelow is the wiring diagram. Why are you wanting to use the wiring in the cab for the auxiliary lights?
If you look at the schematic that was posted for you, there is only 1 relay for the headlights and that lives in the fusebox under the hood.Bc the wires the the head lights won’t work it’s something to do with the ground . I wish it was that easy. I think you have to grab it at the relay down at the kick panel
I appreciate it.. I’ll take a lookIf you look at the schematic that was posted for you, there is only 1 relay for the headlights and that lives in the fusebox under the hood.
High beams are ground switched through the stalk.
