Automatic Tranny
Hi
Yes I have done a search but did not get an answer. I want to swap my 4 speed stock tranny for an auto. What if anything will bolt to the 2f and the tcase? What will need to be modded? What year and type of vehicle can I find the donor parts from. A direct bolt in would be great but I believe is highly unlikely. Thanks
If I recall, there are 0 options for a direct bolt on AND even with modification, the auto tranny demands a VERY small rear driveshaft i.e. stock one has to be cut down. Certainly it can be done-for that matter, anything can be done but with the 40's short chassis, you really are limited. This is, of course, a paraphrase of the article I read so, take it for what it is worth.
your paraphrasing is right.
it'll require drive shaft mods. cross member and adapter kits. shifter. etc.
I don't know about the automatic options on the toyota side, but will tell you that putting in a 700R4 behind a SBC350 left me with regrets.
I would recommend a TH350 perhaps, but would also advise you to look into other tranny options.
Why are you wanting to swap tranny's?
Well, I've seen 2F's transplanted into FJ62's. If you can get a auto tranny and t-case from an FJ62 it should bolt to your 2F. I think you also need a later FJ60 bellhousing.
I don't know if there's room for it or not, but it's something to look into.
I do not want a standard any more, just lazy and want auto. Modifying a crossmember and even a driveshaft is fair trade. I am just wondering if anyone has done it. My 2F is running so I should naturally keep it. If I had to replace the motor then that would be a different story then. I would trade my 40 for an auto 62 if somebody wanted that, but then again that is not an option right now. I really want an auto. Any help or suggestions are appreciated. Thanks
A440F Auto’s bolt on directly to a 2F I recall from my test fitting and I know others have done it. You also need a split tcase from an 88-89 FJ-62 to make it work. I was headed in that direction until my 2f started give me problems and I found a 4.3 for what the 2F parts where going to run.
About as long as a 700R4 setup I recall so yeah some other mods are needed. But the ratio's (4.10's) are the same so it should shift correcltly
I have two used A440F’s (one working complete with everything, other one minus TC and needs some work) crated up ready to be shipped/put up for auction but if you’re interested send me a e-mail to younothat2@nospam@yahoo.com without the spam of course
Brian
