autocad files for the 60 series (1 Viewer)
I have not gone through this whole thread in a while but anyone posted up transmission bell housing patterns? I may be coming into possession of a VW 1.9tdi motor soon and want to mate it to a Fj60 4speed and t case to be used in a series 3 Land Rover. Any bolt pattern files would be helpful for making the adapter plate. I’ve yet to find much on the google.
Has anyone actually gotten the CAD files?
Get me some dimensions I can make drawings.
I have been through this thread also hoping to find something of use. No luck except for pretty pictures. I hope the link below works - this is what I have created in an attempt to design some side step brackets, packing arrangements etc. It may be of use to someone else. Also not 100% accurate but can be scaled based on actual measurements from your vehicle.
A Landcruiser.rar
The archive contains an autoCad 2010 format file with two jpegs that are referenced. Contents look like this:
Sounds like the models that were flying around earlier in this thread are no longer available, or they weren't accurate enough to do anything with.
I made some accurate files for the rear cargo panels of my '84 that I've been sharing around the Mud forum for a while. They are attached below for anyone that wants to use them. If you use them and machine some new panels, post up some pics and tag me so I can see what you did.
  • side panel cnc.pdf
  • side panel cnc.dxf
oh very nice, is that pdf to scale? that would definitely help with damaged door cards
