For Sale Austin TX - Early FJ40 parts (2 Viewers)
Goforth
Austin tx
Selling parts to fund my 100 series project. Prices listed below photos do not include shipping. All parts are assumed sold to first one who claims. I'll update the list periodically.
  1. Early fuel line year unknown, did not work for my ’67 could be for earlier $30
  2. Early Toyota Grill Emblem decent shape $15
  3. Side Apron Emblems good shape - one stud is missing the nut $15
  4. Turn indicator switch Toyota part number 84310-60020 with harness $10
  5. Turn indicator switch Toyota part number 84310-60020 with signal arm $10
  6. New OEM red reflector Toyota part number 81910-69015 $30
  7. New OEM Heater valve Toyota part 87240-60010 should fit model year 73 to 84 $40
  8. Defrost vent guides - bought from cruiser corps. Their site says 67 -74 but did not fit my ’67. $40
  9. Used OEM Kyoto turn indicator lens for early FJ40- free
  10. NEW OEM Kyoto turn indicator lens for early FJ40 Part number 81511-55010 $10
  11. Pathfinder brand reflectors quantity 4 - these were on my ’67 when I bought it. Free
  12. New OEM V Belt Toyota part number 99323-01040 works for 68+ F engine $5
  13. New OEM Toyota Carb Gasket part number 17848-60030 for ’58 to ’69 $5
  14. New OEM Flasher Toyota part 81980-20060 $60
  15. New Thermostat gasket for 68+ F engine Free with other purchase
  16. Vacuum shift valve assembly good for parts $10
  17. Alternator - says Delco Remy. Was installed on my ’67 when I bought it. $10
  18. Early FJ40 thermostat assembly. $25
  19. SOR Air cleaner lid gasket $5
  20. Alternator bracket for F engine $20
  21. Broken alternator bracket for F engine - free to a welder
  22. Steering column bracket $10
  23. SOR gas tank cushions quantity 4 $5
  24. OEM kick vent weather-stripping Toyota part number 55786-90301 quantity 2 $10
  25. Early FJ40 water pump with new water pump gasket $30
  26. OEM Toyota Gas cap with patina $5
  27. New OEM Toyota gas cap part number 77310-60090 $10
  28. New Radiator heater pipe Toyota part number 16577-61040 $25
  29. Used Early FJ40 Temperature sending unit $5
  30. Early FJ40 window regulators $20
  31. Early F engine oil cap $5
  32. Early F engine radiator cap with chain $5
  33. Early F engine water drain plug bought new from SOR part 052-21B $5
  34. Early F engine water drain bought new from SOR part 052-20A $15
  35. Used vacuum manifold fitting bought from SOR part 072-14A-U $5
  36. Manifold stud kit for F engine bought from SOR part 044-02B-KIT $15
  37. Used fuel filler neck with shield $20
  38. Used stainless steel hood latches $10 (pair)
  39. New SOR draglink rebuild kit part 094-51B-KIT $15
  40. Some aftermarket hood cushions $5
  41. New OEM Toyota hood catch (pair) Toyota part 53506-60010 $30
  42. New SOR windshield hooks (pair) SOR part 112-16-oem $30
  43. Used foot pedal rubber Free with purchase to first one who wants it
  44. OEM Toyota dip stick 15301-60030 $10
  45. Early fuel line for F engine (68 +) bought from SOR part number 028-13A-U $50
#8 - do you have 2 or just 1? Hard to tell from the picture.
7, 19, 34, 36 Please.
More:
numbering got messed up in cut/paste. the sticky notes are the numbers. tried to correct
46. old crappy headlights but good connectors - $5
47. Early Kyoto taillights with chrome ring. No rear cone $40
48. Some aftermarket voltage regulator that was on my ’67 with painless wiring kit $5
49. Early headlight dimmer switch $10
50. Aftermarket dimmer switch $5
51. OEM grounding strap from starter to frame $10
52. New OEM toyota mirror arm Part number 87902-60050 with new OEM gasket 87911-90300 $35
53. Early bib lights $20
54. Early license plate light $10
55. Beautifully restored early oil filter housing. This thing is beautiful. Part number 15000-60010 $250
56. Heater switch completely restored by ToyotaMatt $150
57. New OEM headlight switch Toyota part 84110-60030 $25
58. New OEM wiper switch Toyota part 84650-60050 $25
59. Used early FJ40 turn indicators $35 for pair
60. Mirror, circle New Toyota part 87901-60020 2 available $15 each
61. New OEM mirror arms toyota part 87902-60030 2 available $40 each
62. New OEM rectangle mirror. These have the black trim. Toyota part 87901-60011 2 available $20 each
63. Bumper gusset - used $10 for the pair
64. New OEM Inner shift lever boot Toyota part 33555-55010 2 available $5 each
65. New Steering column boot bought from SOR part 098-22A $30
66. New OEM LH Tail light bracket Part number 75154-60012 $10
67. New OEM RH Tail light bracket part number 75153-60010 $10
I'll take 9, 10,11,13,22,31 from the first batch.
And (46 on postit) and (64 on postit)
Let me know how to pay. Thanks.
Thanks, I should have updated the posting to follow. Do you want both mirror arms (61)?
57, 58 , and 29 please
28 if still availible
25 water pump too please
