For Sale Austin, TX: 1997 Lexus LX450 w/ blown engine (2 Viewers)
No F/R lockers; silver; currently in Liberty Hill.
Truck is in average condition for having 230k miles. I purchased in the middle of last year. On the way from Dallas to Fort Worth after buying it, it overheated due to a radiator leak. Trailered it back to Austin and replaced just about the entire cooling system, including the radiator, radiator hoses, and water pump. I did not do the PHH because I only have so much patience, but there’s no indication of any current issues with it (and hey, you’re gonna pull at least the heads so perfect time to do it).
After Thanksgiving I was headed back to Austin from Fort Worth and the engine started to overheat again, vibrate, and lose power. Pulled off into a parking lot and let it cool down. Started it again and got tons of smoke out of the exhaust (light gray, so maybe a mix of coolant and oil). Trailered it back to Austin and the engine wouldn’t start, just made a loud clunking sound. At some later point it started up and ran enough to move it a few hundred feet. Initially hoped it was the head gasket but once we got it back to Austin started working off the assumption it’s probably a bottom end issue.
BUT THEN it started up and, after moving it around a few times, started running a lot better. Idle is really rough, but once the RPMs get over ~2k or so, the engine runs smoothly (...ignoring the large amounts of grey smoke it produces). So, we're back to thinking it's a top end issue (e.g., head and valve stem seals).
Prior to its near death, it was burning oil fairly rapidly.
Things that have been done since I got it: Replaced the shocks with KYB Gas-a-Just shocks and the steering dampener with the Old Man Emu dampener. Replaced front and rear door speakers. Replaced a bunch of other small stuff, including a new Optima yellow top battery. Sunroof leaked so I had standard maintenance done to it by Texas Auto Tops of Austin which solved the problem, which was caused by the drains being clogged. Had Land Cruiser Specialists do about $2500 worth of work, including: new axle seals, brake pads, repacked birfields, wheel bearings, hub seals, cleaned throttle body, replaced EGR vsv, and fixed some vacuum leaks.
I replaced the PS pump, still squealed, so I had Land Cruiser Specialists replace the new one. Still squeals. Replaced the tires with BFG AT T/A KO2 tires, which now only have 5-10k miles. Transmission is a little clunky shifting into drive sometimes but otherwise shifts well. A/C/heater works well.
Discovered the fuel tank has a leak on the top where the fuel filler connects. This has apparently become a common issue and necessitates a tank replacement unless you want to weld on a fuel tank (not viewed as a particularly good idea). Paint clear coat is spotty.
When we got it back to Austin after I first bought it, we discovered that the rear driver side quarter panel had been repainted and the color didn’t completely match (not particularly noticeable depending on the light). The fender flare paint on that quarter panel started coming off/bubbling soon thereafter.
I have a removable roof rack for it.
Other issues:
1. Pinstripes were kinda removed (probably so they didn’t have to replaced after the quarter panel repaid)
2. Minor oil leaks, including the distributor (not surprising on a truck of this age)
3. Lowest part of the side cladding on one side is missing (an inch or two tall piece that runs just below the doors)
4. At least two window seals need to be replaced (it’s safe to assume they’ll all need to be replaced). No issues in rain but result in a lot of wind noise and high pressure water (e.g., from a power washer) will get through.
5. Some of the door seals are starting to lose small chunks. Does not appear to have any impact on the actual seal.
6. Front bumper corner is not entirely flush with the truck (off about a half inch).
7. Rear bumper has a dent/missing paint (sharp linear indentation like you would get from a door edge)
8. Cruise control doesn’t engage; haven’t pulled the code.
9. Triangle trim pieces in the corner of the front doors broke while trying to replace the speakers and will need to be replaced.
10. Some of the dash lights probably need to be replaced.
11. Front driver’s seat is starting to wear and get stiff but doesn’t have any major cracks yet (maybe still savable with some proper conditioning).
12. Front seat won’t move forward or back.
13. Carpet stain in the second row next to the center console.
14. Rear speaker covers were broken before replacing the rear door speakers; probably some modification required to get them to fit over the new speakers even for non-broken ones.
16. Three of the locks don't work (motors, most likely; driver's front and both rear doors)
17. Front driver side window has a broken track
18. Probably some additional minor issues I’m not remembering.
All total I probably put $3500 - 4500 into it before the engine issues. With the exception of the engine and rear quarter panel, most of the stuff is fairly minor/easy to fix (and the quarter panel is purely cosmetic).
Clean title. I have ~200 detailed pictures for potential buyers.
$5000 very negotiable
(super excited to see how many people still talk s*** about the price)
Curious, what would you have figured the value of this truck if it had no engine issues, 230k and condition listed??
I think you just did.
Not remotely. I already made it clear that the price I listed is not the lowest price, even going so far as to double emphasize the price negotiability. So I basically have three choices:
1. Decline to state any price.
2. Blatantly lie by just adding the cost of an engine replacement to my "list" price and state that I believe that's the value.
3. State a value that implicitly lowers the upper bound that was established by my "list" price.
The only logical choice is #1, because it doesn't actually provide any additional information to the other side that can be used to guess what the lower bound is. To put it another way, I made it clear that I don't believe that the listed price corresponds to the value of the truck; all my response does is reiterate that exact point without providing any additional usable information.
What does it matter the possible price if no engine issues? Probably in line with other vehicles listed here in same condition. He stated a price that was not set in stone. Work your way down from there.
This is why I avoided posting it on here for a few months. I priced it at $5k everywhere else to scare off the low ballers. I post it here and can't put a different price, so I make it abundantly clear that the list price is not meant to reflect what I think the value is...specifically to try to avoid this stupid s***.
WHy not simply put a price for what you feel its fairly worth in its current state??? Vs monkey around asking obvious ridiculous prices and putting off any people that might "seriously" be looking to pay a "fair" price.
Personally when scrolling thru for sale ads.....and seeing a price that doesnt reflect reality.....i dont bother wasting time if i deem a seller to not be at a realistic starting point for negotiation. and $5k puts you into that pool of sellers. if you said something like $2500obo. Youd likely get alot more interest.
Personally when scrolling thru for sale ads.....and seeing a price that doesnt reflect reality.....i dont bother wasting time if i deem a seller to not be at a realistic starting point for negotiation. and $5k puts you into that pool of sellers. if you said something like $2500obo. Youd likely get some people off the fence.
Why not simply read what's already been posted? Vs monkey around asking obvious ridiculous questions that have already been answered?
Mocking aside, starting with "what you feel its fairly worth" is perhaps the most idiotic way to try to sell something there is.
Well, if that were mine - and i was interested in selling it. I would already know that in my town a running driving 160k miler went for $3k within 2 hrs. and a much cleaner than yours white one/cloth interior (far more desireable combo than yours) with no engine or trans sat for a few weeks at $1800.
Given " what i know" and what i would feel is a fair price......id start somewhere at $2k-2250 obo. to be in the correct range to at least be deemed as a "serious" seller vs not so serious @$5k asking. you likely reside in texas....but arent a Texan if i had to guess.
I spent *months* looking for this before buying it. I'd love to see a link to one that's cleaner than this and running for $3k.
And I was born and raised in Texas.
Again , all your arguments,,,,,spending months looking for a clean one.....or my tires are worth "x" simply scream that you have the time to wait around at a hopium pricepoint. And thats fine. More power to you if you dont need to sell. Keep it at $5k obo and shoot for that needle in the haystack. best of luck with your sale.
You spent months looking.......how much did you pay for that btw when the engine was running ??
No link? So I guess you're full of s***.
Here are some local examples...zero of which support your numbers.
