I am going to be installing a Aussie Locker in the front of my 1973 FJ40 I have one in the rear already I just need to know is there anything special I should know ? It should install same as the rear correct ? Thanks in Advance
and you get to do it on the bench not sure if it easier .after the fact that you had to dissassemble almost your whole front end and pull the diff..no c-clipsand you get to do it on the bench not sure if it easier .after the fact that you had to dissassemble almost your whole front end and pull the diff..
Thanks Guys I have the third member out and will be installing the locker tommorow
Take lots of pictures and post a tutorial!
