kevin in okinawa
EGT sensor and gauge from Auber Instruments. Installation was pretty easy...even though I missed with the 1st hole drilled. i tapped it and plugged it with a bolt.
Automobile Multimeter for EGT, Boost, 24VDC [SYL-1813-24] - $48.50 : auberins.com, Temperature control solutions for home and industry
2nd hole: used a 8.5mm drill bit. spend $10 on a nice new bit. a little bit of debris may have fallen in, and I couldn't find a magnet small enough to fish for it. truck runs fine though! tapped it with a 10mm (?), 1/8 NPT. screwed probe in about 1/2way into header. Ran the nice SS line thru firewall, and mounted the gauge in the dash above the ashtray...easy install. turned up the fuel one complete turn, boost upped to 1 bar (14 psi), egts just north of 1200 at max...tons of more POWER!
upload failed..i'll try again later.
