Attaching 8274 to FJ40
Cruiserdrew
On the way there
Sacramento, CA
I just bought an 8274 (used) but I need a low cost way to attach to the front of my FJ40, Any reccomendations? This is my 3rd truck, I only use it on trails like the Rubicon, so it doesn't need to be beautiful, just functional and cheap. I have seen a few aftermarket bumpers but most are more $ than I want to spend. All suggestions welcome.
If you weld it only takes a piece of 1/4" steel plate about a foot by a half a foot, or look in JT and MAF for simple store bought bumpers.
big peice of c-channel for a bumper, weld on a big steel plate to mount the winch, even if you don't weld, it's not going to be expensive to get done. I can link a picture of mine once there's enough light to go take one.
Thanks for all the suggestions. I'm leaning hard toward the MAF channel bumper since it's $125. I'd need to make it shorter though!
If you end up welding the plate to the bumper, be sure to only run a few- maybe 4, shortish (2"??) beads along the top and bottom, and let them cool before doing the next one. When I did mine (I am a a bit of a moron)- I ran a few long beads and the metal bent forward. I had to cut it back and start over. Sucked. :D
-Dustin
I orginally built my bumper in August for use with a pto winch. Then two weeks ago instead of coming across the last piece to my a la carte pto I found a deal on a 8274 that I couldn't pass up. A angle, grinder, a holesaw, and a 8"x12"x1/4" steel plate later I had my new electric winch mounted up. The steel was like $6 and the new grade 8 fasteners were like $2 at Mclendons hardware.
Turned out nice. That's looking pretty close to what I want to do except I'm going with 2x4 tubing. Can we see some closeups of the bumper mounting? I was planning on having the 3/4" clevis bar run through the bumper along the frame a few inches and have 2 bolts on each, then maybe a piece of angle iron for added reinforcement.
Looks nice. :beer:
budbuilt.com for winchplates, $39 might be something you could use.
Get yourself one that was originally designed for a Jeep. You will have to do some cutting in order to get the tie rod that runs from the pitman arm to the bellcrank but it can be done. It looks really nice and professional and the best part, you don't have to cut your cruiser.
Best regards,
Guys-Thanks. I've spent the last couple of days making sure the Winch is good to go. The brake system threw me for a bit, but I have that under control I do have a Saginaw box and it looks like the winch will fit in a low bumper mount with just a bit of room to spare.
Any of you guys with the 8274s change out the lube oil in the gears? Finding the specified Non-detergent oil is not easy, I was wondering if gear oil would work since it's lubricating gears in the drive unit.
older Warn 8274 mount on my 82
