ATF oil level - 06 LC
TheForger
Little Rock, Arkansas
You must remove the fill plug of the transmission to check that’s it’s at the top. Not pouring out but right at that edge. There is no dipstick for that year
Santa Clara, CA
Dumb question: Where is the fill area for the ATF? the only cans i see under hood are PS and Brake reservoirs :)
It is more involved than that but I can't search now.
BuckeyeFan
WWHD?
Chicago
You don’t use the fill plug to check the level like you do for the differential. There’s an overflow plug on the pan a few inches away from the drain plug. In a nutshell, you bring the transmission to a certain temperature, park it flat, remove the overflow plug- ATF will drip out when at the right level. Access an fsm for the details.
the fill hole is a large (24mm?) plug high on the drivers side of the transmission housing. The shift linkage runs right over the top of it. Picture of the fill hole: Lazy man WS ATF filler
Santa Clara, CA
I was looking at a video and seems like the LX470 has a ATF dip stick. But Anyway, thanks for the pointer for the overflow plug. I do see one next to the drain plug.
I will locate the ATF on the driver side etc. will nudge you guys if still unlucky.
