Well dropping the pan does get some more fluid than just a drain, 6qt vs 4qt but this is still less than half the total quantity in the system,
Here is what I did/am doing, right wrong or indifferent it makes sense to me
(copied and updated from previous thread)
When I got it at 106K the fluid was slightly off color, not brown yet but not new looking either, bought 2 cases of chevron ATF, used 3 or 4 to flush the PS and then drained the tranny pan (4 of the 12-16qt capacity) twice within a few days and then at every oil change after that,
This way is cheap and easy to do in your own driveway, just scoot the oil drain pan back a foot and pull the tranny plug wile you are under there for an oil change, as batches of new fluid come in with their new detergents, additives and solvency they clean the parts to a certain extent, when the fluid is drained some contaminants go with it, after enough of these the majority of the old fluid is gone and any of the sludge or varnish that will come loose, has come loose, and is gone as well,
<hear-say> some also say that it is better to slowly introduce clean fluid to old fluid in a transmission, especially one that has been neglected, don’t know how accurate this is but cant hurt? </hear say>
When my supply was down to about 7 qt's I pulled the pan, cleaned the pan, filter and the 4 magnets, there was a good bit of fine powder/glitter settled in the pan even after all those drains. some of it stuck to the magnets some did not, all of it was gray. But no bits big enough to see individual particles, all fine powder, this seams consistent with what I have seen on good tranny’s, and much better than I have seen in bad ones, the drain point in the pan is kind of high (assume to keep it out of harms way?) so there is a sump area where this junk settles that does not get drained by the plug alone. I would be interested to hear what other FZJ-80 users are seeing in the pan.
Reinstalled everything and filled with the last of my dino, this way if my FIPG install leaked it would only be the cheap stuff not a pan-full of expensive synthetic
Started doing drain/fill with M1 ATF (good experience with it in the past) about every other oil change or as I feel like it. After enough of these changes the fluid will be all synthetic, in the mean time it will be a mix of newish dino and syn witch is better than a mix of old dino and syn.
Here is a spreadsheet that figures the ratio of old fluid to new fluid on the pan drain method
http://webpages.charter.net/raventai/Tranny4Bobistheoilguy.xls
The flushers claim to exchange all of the fluid, claiming DIY methods leave dirty fluid in the tranny, the second is true but I just don’t see how a flush machine can keep from mixing new and old fluids in something as complicated as an idling transmission. It has pumps, several separate areas that hold large amounts of fluid, hundreds of passages spinning gears all of witch moving fluid
