Pretty dire.. Its 275 degrees I believe.
I overheated as well last July crossing a macker of a mountain pass in 2nd gear.
Here's what you do to keep the trans on the 62 alive for as long as possible:
- Drain your current fluid, its burned....
- Remove the pan, so you can clean the filter and the inside. I added 2 more magnets on the inside of my pan.
- Add a trans cooler, find the biggest one you can fit.
I bought this one for many reasons and after much research. Its Stacked plate, holds a lot of fluid, keeps pressure drop low and cools really well. I had to add like 3 more quarts, which is a great thing.
Do not use AN6 couplings... they will restrict the flow by a lot.. factory inside diameter is more like 8 AN.
- I installed a temp gauge in the idiot light sensor position on the transmission. Can give you Amazon URL's to what you need if helpful. Its really nice to know what temps you're running at....
- Do a passive flush ( Rodney Flush - search the forum)
- Use an Allison trans. proof synthetic fluid. Transynd or Mobile Delvac 1. I use Delvac, such good stuff. I've tried many brands... Even Amsoil Synthetic ATF didn't work that great for me.
Rodney, a440f trans guru, said to use an Allison synthetic... I went with Delvac and it actually cured some of the issues I had with my AT, like not shifting to 2nd gear when cold.
These days I struggle to get my transmission hotter than 180 degrees when offroading in 4 low...
Peace of mind and the transmission feels and shifts solid. Hope that helps. I might go the manual route at some point, but I kinda like the AT.
Comparison with old Hayden 10x11inch cooler pre final installation:
Transmission Temperature :
