I have done several searches, but not come up with a matching scenario. Our 1988 FJ62 has the AT Oil Temp light on all the time. The light came on after changing the transmission oil filter. I had removed the transmission to replace the rear main seal. While the transmission was out I washed off the dirt and grime, let it dry, and then replaced the filter. After putting things back together, the transmission performs as it did before. The only difference is the AT Oil Temp light is on all the time. For the first several days the light would come on several minutes after start up. My daughter drives it to school, we live about a mile away. It is winter in Idaho so, cold mornings and she warms it up before she leaves. The oil is not hot in that amount of time. I did mess with the sensor connector a little bit, made sure it was dry and clean. Now the light comes on right at start up and stays on until the truck is shut off.
Is it just the sensor or could it be something else? I do have a sensor on order, but I'm wondering if it could be something else.
Thanks for any information or help you can give.
