I've owned my 2006 LC 100 with 125k miles for 2 1/2 months. I have the service history and baselined as much as I could. Not a peep (no CEL's no codes) out of that truck in the entire time (in stark contrast to most of the German cars I have owned in the past).
Now I'm on my first major road trip, and its an epic one: Southern CA to Southern Maine. I thought I had little to worry about since in driving the LC 100 for about 10 weeks there had been no signs of trouble.
I'm carrying a relatively heavy load, including a car top carrier and a cargo carrier on the tailgate. Yesterday, on I-15 in the CA desert (ambient about 105ºF) going up the very long Baker Grade, I am running cruise control at about 70 mph, with the trans selector in (D). I could tell when the torque converter lockup would disconnect, then if that wasn't enough it would drop into 4th.
The trans ended up holding 4th gear for a good long while on the Baker climb. When I would try to adjust the C.C. speed up a bit it would sometimes drop into 3rd. I didn't think much of it since the trucks computers (C.C., ECU and transmission computer) were controlling things and I never saw the coolant temp never went above 93ºC / 199.5ºF (50/50 Toyota coolant and water with 1 bottle Red Line Water Wetter).
After the Baker Grade this is one more climb before the Nevada border. I go up it the same way as before. Then on the way down I can tell something is wrong. The engine seems WAY down on power, and I can't increase speed even though I'm going downhill.
Then I get the AT Oil Temp light and somehow the engine stalls. This is at about 70 mph on an interstate. Once I get a sense of what's going on, I switch into neutral and coast down to the next exit.
I pull over and pop the hood to help the trans cool down. I don't see any obvious signs of trouble. I check codes with my scanner and the only thing I get is "System too lean bank 1/2". I clear the codes and having allowed some time for the trans to cool, I restart the engine and continue.
SO:
I need to continue the trip
I have the very steep 11,000ft+ continental divide to conquer tomorrow which makes Baker Grade seem like a mole hill.
Anyone have any advice?
Anyone experience anything like this?
Do I need to have anything checked?
Is it just a matter of climbing more slowly?
Is it best to not use cruise control and avoid 3rd gear on climbs?
Thanks in advance for your advice which is greatly appreciated!
SO:
