I got a front skid plate for my stock height LX a little more than a year ago. Great fit and finish. I think I may have need to get a longer center bolt. Seems to be about the same weight as the stock piece.
Hi - Any promo codes for ih8mud?Hey there, -
Front skid-plate (558055) - 22 lbs
Gear skid-plate (558063) - 40 lbs
Transfer skid-plate (558067) - 22 lbs
and in total - 84 lbs
Hopes this helps lmk if there's anything else we can help with.
Best,
Reut @ ASFIR
Not at the moment i'm sorry..Hi - Any promo codes for ih8mud?
A few suggestions for the front skid. Make the rear holes slotted. This makes it easier do put on by sliding it on to half screwed bolts, and levering up. I think that would also help to alleviate back to front bolt hole fit issues. To make that work the overall length needs to be just slightly shorter.Not at the moment i'm sorry..
Thank you! If you have pics / diagrams to send us it will be great.A few suggestions for the front skid. Make the rear holes slotted. This makes it easier do put on by sliding it on to half screwed bolts, and levering up. I think that would also help to alleviate back to front bolt hole fit issues. To make that work the overall length needs to be just slightly shorter.
We usually don't make changes to our products without R&D in our manufacturing factory / by one of our representitives, but we are always happy to learn from your experience.
Cheers
Sounds great! Do you have pics or something to share?I did this to mine to get it to fit with the slee diff drop. Rather than trying to just elongate the holes to the rear, I just slotted them. Added benefit is as stated above, being able to slide it onto already started bolts.
I will do this. I think I have a similar looking custom-made skidpan on my Tacoma with slotted rear holes.I did this to mine to get it to fit with the slee diff drop. Rather than trying to just elongate the holes to the rear, I just slotted them. Added benefit is as stated above, being able to slide it onto already started bolts
Unfortunately no :/ It's a bit more complicated with not having a gas model (or a lot of 100 series for that matter) in Israel.
We only release a product when we are certain it has a 100% fit and after it is tested on the vehicle itself.
I guess slots can mean two different things: they can be elongated holes that make up for the seeming misalignment of the predrilled holes to bolt on to at least some of our vehicles, or elongated holes that reach the end of the plates to make attachment easier.
Mine is an '05 LX and I had difficulty getting the front skid's long bolt started with the spacer too but found by loosening up the front bolts and propping up the rear most portion of the skid plate, I finally got it started and tightened... It was a little frustrating because there isn't a lot of room between the skid and the underside pieces being protected by it and without a second set of hands or a prop agent, I could see how some have resorted to modifications.reDTC72
Hmmm....
Mine is a 2005 LC just like yours. All stock.
The front plate needed the back holes lengthened by 1/4 inch to go on.
There is obviously a source of variation, either in our rigs or Asfir. Slots seem like a reasonable way to address it.
Typo that I just fixed. I have a 2006.reDTC72
Hmmm....
