Are Volk wheels an absolute upgrade
Heres my share
Rock Warriors and load range C BFGs AT KO2s 285/70/17 , are about 76 LBS per corner
TRD 17x8 Rock Warrior Alloy +50mm offset 24lbs
Good catch. I’ve been looking at the heavier 285 70 r17 for weights. I assumed it was necessary for the 200.
is it the case that the lighter load range c tire is appropriate for the 200?
A c range tire will easily handle the loads a 200 is designed for. The only reason people go to d and e is to get the theoretical heavier construction and greater protection against things like sidewall tears off road… or if a given size just isn’t available in anything lighter. Like 285/65/18 used to be.
Tires vary, so a c rim tire might well weight less than the same rim with an e tire on it. My tires plus 18” cast rims are around 100 lb per corner.
Zero offset doesn't "tuck" but if it did this is proly what it would look like 🤪
