Are there any threads of restorations that were NOt frame off jobs?
Discussion in '40- & 55-Series Tech' started by 1MOA, Dec 3, 2017.
  1. 1MOA
    1MOA SILVER Star
    205
    Media:
    4
    176
    Nov 7, 2017
    Warrenton VA
    Just wondering if there are a few threads of restorations that were NOT frame off complete tear downs?
  2. DSRTRDR
    DSRTRDR I can mangle anything ... SILVER Star
    14,364
    Media:
    42
    Albums:
    1
    1,532
    Jan 4, 2005
    Baton Rouge, LA and Fountain Hills, AZ
  3. RWBeringer4x4
    RWBeringer4x4 Mechanically Challenged SILVER Star
    3,712
    1,540
    Jul 11, 2012
    The People's Republik of Maryland
    Mine is still in progress, but not a frame-off. Just about done with the mechanical parts, bodywork will come next.
    Link should be in my signature line!
    1MOA likes this.
  4. Tancruiser
    Tancruiser
    1,475
    Media:
    2
    Albums:
    1
    1,362
    Sep 16, 2006
    Steamboat Springs Colorado
    I’m not doing a frame off on my LV ,are you kidding me I want to drive this thing.
  5. bikersmurf
    bikersmurf
    8,210
    Media:
    60
    Albums:
    4
    1,579
    Apr 2, 2008
    Victoria, BC
    My rebuild is below... not a frame off... although it did include a new frame.
    1MOA likes this.
  6. Doctor do Little
    Doctor do Little
    522
    542
    Sep 24, 2011
    Boots are made for walking :)
    [​IMG]
    Cheers
    Peter
  7. GA Architect
    GA Architect SILVER Star
    2,577
    4,679
    Feb 14, 2014
    Woodstock, Georgia
    I've done the best I could with what I have learned here on MUD, and I'm a architect not a mechanic.....check my signature line. I chose the direction I did because I wanted a driver that I wasn't timid to drive.
    Two helpful words of advice; patience & research.
    Best of luck with your progression. The good folks on this forum are an invaluable resource with these rigs.
    gator25, GHalll, sterling and 2 others like this.
  8. subzali
    subzali
    3,339
    317
    Jan 31, 2005
    Denver CO
  9. Pommy
    Pommy
    76
    83
    Sep 19, 2016
    Brisbane
    This is my build thread mate. An unexpected rebuild that I have done mostly in a single car garage by myself. It’s not exactly up to restoration standard so it’s not for the faint hearted! I will be updating it soon once I get some free time.
    Surprise BJ42 strip down and rebuild!
  10. Jdc1
    Jdc1 SILVER Star
    2,445
    2,585
    Sep 9, 2013
    Akron, OH
    gator25, ginmtb and thebigredrocker like this.
  11. Strait Cruisin
    Strait Cruisin
    310
    Media:
    40
    Albums:
    1
    247
    Dec 28, 2006
    Port Angeles
    It's not so much on the frame or not, it's planning the work and time in sprints and projects so the downtime is the least. The worst thing is having to put it on hold and it be a no-drive no-fun shop queen.
    gator25 and 4x4veteran like this.
  12. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,878
    Media:
    79
    Albums:
    4
    2,852
    Mar 6, 2005
    Mauldin, SC
    Or tearing it apart and then sending it to me to finish. If you have the money and time then a frame off will save you time and money down the line. If you don't have the money or time then a frame on in the way to go. As well space is always a big issue with a frame off.
    Strait Cruisin likes this.
  13. Strait Cruisin
    Strait Cruisin
    310
    Media:
    40
    Albums:
    1
    247
    Dec 28, 2006
    Port Angeles
    So there's fast, good and cheap. Pick 2 of those.
    I couldn't afford to have people work on my stuff.
  14. 4x4veteran
    4x4veteran
    288
    1,198
    Nov 6, 2013
    Years ago I started out working on my own stuff because I couldn't afford the labor. Now that I can afford it I don't feel right having someone else doing it.
    I farm out some things like head work,balancing, boring and such but I put it all together.
    A couple years ago I had a bypass. Shortly after that my wife's dodge needed a new water pump. It is not a simple job so I let her talk me into letting a garage do it for fifteen hundred bucks.
    Never again! A couple weeks after the work I was luckily almost home when the plastic housing on the front of the engine split and lost all the H20. I watch my gages closely so shut it down before it got too hot for any period of time.
    After I got it towed home I started my inspection. I had to pull the FI plenum and found the plastic housing broken. I am sure that the mechanic cracked it while working on the car and it finally gave out after a few hundred miles.
    I am confident it wouldn't have happened if I had done the job.
    From now on I don't care if I am having a fricking stroke I am doing it my self.
    I am not fast but I do save a bunch on labor and use the savings toward doing it right.
  15. RWBeringer4x4
    3,712
    1,540
    Jul 11, 2012
    Mine has been down, for the first time, for over a year since I pulled the driveline, a project I was planning to have done in 3 months. It’s the first time I opened a can of worms that really had me second guessing myself. I’m now starting to put it all back together, and I’m so glad I bit the bullet and did it. I’ve always tried to take everything in manageable, practical chunks that keep it out of commission for a few months or less, even at the snail’s pace at which I work. It’s definitely doable, especially on a 40 where everything is easily accessible, and you have the collective knowledge of these folks behind you.
    The clustertruck won’t ever be beautiful, but if it was, it wouldn’t be the clustertruck.
    I farmed out some early projects to a shop (power steering and a transfercase replacement). When I got it back 2 months later with the steering wheel misaligned by 45 degrees and drove it home to find my transmission completely empty of gear oil, I made the decision to do everything possible myself. I may have no idea what I’m doing, but at least I care about my results and can take pride in the accomplishments. Plus, working on the 40 has given me confidence to tackle bigger projects on the wife’s and my daily drivers (Mazda 3 w/ 140,000mi and Altima with 196,000mi), so applying what I learned on the 40 likely saved me a few thousand in labor costs on those vehicles too along the way.
    SMG, gator25 and Strait Cruisin like this.
  16. GA Architect
    2,577
    4,679
    Feb 14, 2014
    Woodstock, Georgia
    QUOTE of the MONTH right there!!!! Good one, Rick!
    100% of the peoples in here, were all at this point, at least once in their life. Some of them found wrenching on their rigs so rewarding, they became passionate about their skills and made a carrier out of it.
  17. FixedIt
    FixedIt SILVER Star
    461
    87
    Oct 31, 2011
    Gainesville, FL
    My 40 took a couple years, and my buddies and I did the work. I even painted it myself. It wasn't technically a frame-off but we did replace the body mounts and the frame was painted. Tons of fun, frustrating at times but it looks and drives pretty awesome. Now I just need to find a way to store it here in Tampa and not 2 hours away in Gainesville!
  18. Trollhole
    20,878
    Media:
    79
    Albums:
    4
    2,852
    Mar 6, 2005
    Mauldin, SC
    Ain't that the truth. Though there are a lot of people who are not on here that had a great idea but got way over their head. I say if you can afford to do a frame off in your time then do it if you want to get the best results. Plus it is just far easier.
    My second 40 I did a frame on and now wish I would have taken the tub off and had the frame and tub blasted and painted. 10 years later I'm going to have to do it all over again.
    SMG and GA Architect like this.
  19. ginmtb
    ginmtb '74 FJ40 - my first! SILVER Star
    2,908
    3,089
    Jan 26, 2014
    Danville, CA
    I have a 75 that will be a frame off restoration since it is already taken apart and is in pieces. I’m excited by the prospect of it being “easier” and my results being better. I’m amazed at how fast they “can” go. Only thing that is holding me back is space. I don’t have the space for it.
    However, I would not trade the experience I’ve gained by doing my 74 as a rolling restoration. I was not a car guy so I’ve had to learn just about everything (I used to change oil on my car at one point lol). Plus being able to enjoy the cruiser while being restored was key - while I’m an “all in” type, who knows if the frustration of learning on the fly on a frame off would’ve driven me away from it. And actually I really like the patina of my 74 and it will always stay that way. Glad I didn’t tear it off and paint it.
    SMG and thebigredrocker like this.
  20. Ming89FJ62
    Ming89FJ62 I smell bacon GOLD Star SILVER Star
    1,530
    243
    Jul 31, 2002
    Palatine, IL
