Are the radiator mounts the same in an FJ80 as in an FZJ80?
Red Triangle
Are the radiator mounts the same in an FJ80 as they are in an FZJ80? I need to order my Ron Davis radiator and they make a radiator for the stock FZJ mounts. Having a 92 FJ, it would be handy to order the stock setup with my electric fans built in for my sweet 350 V8 setup. I need to know if the mounting holes and dimensions are the same on both radiators. Many thanks as always. :D
powderpig
Boulder Foothills, CO
Mounts I believe are the same, what is not is the in and out on the radiator. different sides of the radiator. So a 93 and up radiator will not work for a 91-92 radiator. Just a heads up for you to make sure that is what you need. later robbie
