Are the OEM UCA ball joints greasable?
California
I have grease stains right below them and I’m wondering if I need to re-grease them? Don’t see any zeros though…
Sometimes a little grease might wick out through the taper/boot over time.. think just enough to make the metal parts close to that area look wet. If you see anything more than slightly oily parts, yes, probably a tear.
But no, no zerks on factory ball joints that I know of, and still they have a long service life.
Ok and are they replaceable?
Yes, though they usually last a very long time and when they are finally done, the inner bushings are pretty bad too, so many just replace the whole arm.
They can be pressed out/in the arm with a press and the correct adapters though. I did this job on a friend's taco with a screw-type balljoint press and it was a total pain in the ass. I wouldn't do it again without the arm off and in a hydraulic shop press.
All of that said, I definitely wouldn't replace them unless they are mechanically worn out. A little bit of grease weeping out the shaft seal isn't anything to be worried about.
Have any pictures?
