I got my first 100 series this summer. I tested out the climate control before I bought it, but I'll admit I probably didn't test how WELL it worked given it was summer. Fast forward to now, when the temperatures have been hovering around the lower 40s to upper 30s. I've found that to stay comfortable I have to have to have the temperature set above 80 and the fan speed on medium or medium high continuously. I've also found my feet are like icicles every time I drive it. I get surprisingly little air out of the foot vents even if I select feet only and turn the fan on high.
Is this typical? I'm wondering there is an issue preventing the air from getting to the lower vents. The heater in my 4th gen 4Runner which is only a few years newer is far more effective. If I leave the heat set on 80 at medium high at the same outside temps I'd be in a sauna in no time. I also get a lot of air from the lower vents. If I where to be in sub-freezing temperatures I wonder if I would need to blast high heat continuously to stay comfortable in the LC.
I know some of you folks are in colder locations, so I'm curious what your experiences are.
Oh, and I get no warm air out of the upper vents in the 2nd row...
