Hello!
I recently installed an ARB Modular rear bumper to my 2000 Landcruiser, and other than rust and the welded nuts breaking off the frame, it went smoothly. I wired in all the lights using the loom provided with the bumper, and while at first everything worked perfectly, after driving a few miles I discovered that all the right turn signals were not working. The left ones work perfectly, but the right will not respond. To add to this, my tail lights no longer light up, but my brake lights work when applying the pedal. I replaced the tail light fuses, brake light fuses, and hazard turn signal fuse, but it still did not fix the problem. the turn signal fuze was blown so I replaced it with a 30 instead of a 15, thinking that the additional two turn signal lights added with the bumper were drawing too much power. Any help with my no right turn signal or tail light issues would be very much appreciated. Thanks. Tom.
