ARB locker question for my 76 FJ40 ARB RD 153? (1 Viewer)
East side of TN
I am going to pull the trigger on an ARB and install it myself but when looking at the chart it seems everything is for a 1977 and up and mine is a 76. Was there some kind of change and ARB's only work in '77 and up FJ40? could it be spline count?
Here is the link I am looking at YOTA ARB List
thanks
Dave
That's YotaMaster's list. Look in the ARB listing. The lockers are the same for 76 and 77 semi-floating rear. Fronts are the same up to 89.
Edit: Hadn't looked before, but YotaMasters list is the same as ARB.
thats i could not find anything on the 76. if the are the same as the 77 im golden. What do people do with pre 76 then?
Thanks, Dave
Top line for the front, third line down for the rear. The earlier carriers used a 45mm bearing. You need to use the 50mm bearing.
Must use late model 50.00mm (1.969") ID bearings with this application. (ARB Part No. 160116)
LandCruiser 40, 55, 60, 62, 72, 73, 74, 75 & 80 Series, Lexus LX450FrontTo 198912 bolt, full floating33 (1.31″)30AllRD142
1990-9710 bolt, full floating33 (1.31″)30AllRD132
Rear1969-7612 bolt, semi floating, 45mm bearing ID33 (1.31″)30AllRD153
1977-8912 bolt, full floating, 45mm bearing ID33 (1.31″)30AllRD142
1990-9712 bolt, full floating, 50mm bearing ID33 (1.31″)30AllRD142
1977-9212 bolt, semi floating, 50mm bearing ID33 (1.31″)30AllRD153
Thanks, Dave
Dave;
I have a '74 (Oct '73 Production) and I bought TJM (Air) Lockers for my FJ40.. BUT, the TJM's are for "Full Floating Axles", only..
I bought a '78 FJ40 Rear Differential as it is Full Floating.. this way, both my front & rear Lockers are the same "part/model number".
BTW, the TJM Lockers came with Nitro Chromoly Rear Axles, as well..
Charles..
