Has anybody had this problem, and if so what did you do?
FJ40-GARAGE said:How is it wired?
Just to the Cigarette Lighter?
What amperage of the fuse?
Biff said:The compressor is wired directly to the battery, and fuse amperage is 30. Checked the battery its fully charged, the lockers seem to be getting power, so the only thing I can think about is the wiring harness or the compressor.
FJ40-GARAGE said:30 amp fuse blowing........thats very strange
Check the wires, maybe its a lose solder connection inside the compressor?
Does it start to run and dies then or doesnt do anything at all?
Check the switch........if it doenst run with a relay......these compressors produce much higher shorttime amps when they reach the turnoff pressure.
(hope my lousy english is well enough to know what i am on about)
Poser said:Victor-
Did you get this figured out?
Bryan E said:Hi Victor,
Have you had any other issues with the ARB lockers or gears you installed? I'm still planing to get my ARB and 4:88 gears installed this spring.
Thanks,
Bryan
