ARB Bumper and T Max Winch?
Yes it will.
I have the ARB winch bumper with the Tmax 10000 lb winch.
Not sure which model 10000lb it is, but i needed to add a few washers to space it out so the motor fit.
No biggie and it works like a charm!
same here....added a washer to space the mount bolts back and it fit perfect....
just put new rope on my TMax too!!
Ditto.
Yep. I have the ARB with the t-max 12,500. I also had to use a few washers to space it off the face, but it works great.
I have this exact setup as well. I don't recall if I needed to space it back or not, but it fits just fine. Make sure you connect all the cables especially the ground wires before installing. or you'll end up installing the winch twice. ;)
Oh, yes, VERY true!! I ended up installing mine 3 times i believe.
Ha HA HA yeah that ground wire was a pain!
I thought gonna need the same setup with a MM winch .. ( electric ) does anyone have pics of the washers . ?
the washers I used were round and had a hole in the center.... :p
(sorry....they were just plain ole off the shelf stuff...nuthin fancy)
I just wonder about the washers already installed .. :P but ok was my bad .. to stupid question ..
