ARB abd Warn on the way! (1 Viewer)
MN physically, MI spiritually
ARB and Warn on the way!
Ordered the ARB and the Warn to cover a bet with the kid. Do you have any install horror stories or things I should watch for when putting these bad boys on? I have read the threads so I am looking for any additional info you might share. :D
I'm officially jealous! :flipoff2:
Saw the post on replacing bulbs in the ARB so not to melt the reflectors. Can some one expound on that as I am not perfectly clear on the need for a bulb change? Thanks.
If you wire the lights to act as "parking lights" and not "turn signals" as intended, you need to reduce the wattage of the bulb. The original 5w bulb left on constantly as parking lights will melt the housing.
I had to lube, dremel, my ARB inorder to make it fit on my frame. Once it was on it looked perfect.
mine slid right on, even after being in an accident which is why i changed it
I Put a huge cam strap on my frame rails and cranked down in it to help it slide on .. took a little love but this is BOLT on.. its a peice of cake. just have 2 people
