Aqualu tub fitment issues
  • Thread starter TrailRunner40
  • Start date
  • Watchers 9
White Stripe
White Stripe
Thanks Rainman and not yet @White Stripe . I wanted to get some feedback on here first to see if there was anything that I missed or if I was an anomaly. I have emailed Aqualu a few times to get some help but have not heard back so I'll try calling. This has just been a complete nightmare and I should have kept my original tub and patched it. It would have been quicker and cheaper in the end.
Without pics it's hard to tell what your issues are. Did you look at my build thread? You have to keep in mind a aqua is not a duplicate of a original tub. It is different. Things will fit different. Door gaps will be different. But in the end it can look very good.
TEakins
TEakins
Ted
Columbus, Ohio
Yes my gas tank cover fit everywhere except the door jam, also. I have a tub from 2004. You would have thought they could have tweaked it after 17 years. My front clip is all aluminum except for the hood. Man that took a lot of blood, sweat, and tears to find the best alignment. It still isn't perfect, but I don't notice it anymore. Keep the faith, improvise, and adapt.
Z
zerotreedelta
Wausau WI
Ironically, there was the same gap at the door jam on the CCOT tub - cover sat about 3/8" high along the sill. Definitely funny stuff in the aftermarket world...(tank was new OEM).
The upside is that some of the things that grind your gears during assembly are much less noticeable once it's all together.
Jetlander
Jetlander
Idaho
Very true. All I did to make it work was trim off the 90° bend on the tank cover that bolts to the door jam. It looks fine and only the most hardcore purist would even notice.
Similar threads
Cruising Canuck
Replies
20
Views
487
Cruising Canuck
Cruising Canuck
C
Replies
Views
120
Critchie
C
Caribou
Replies
16
Views
714
Pierps
JustJay
Replies
1
Views
194
Vandal FJ
Vandal FJ
