Anyone with 95-97 need you to listen next time you shut off truck.
I'm trying to track a coolant issue, and one significant clue I thought meaningful may not be at all. I heard what sounds like faintly boiling water in my catalytic converters (two large canisters under passenger door). Since then, I've jumped out to listen to them each and every time we go somewhere and it appears to always make this sound.
To clarify, this is not the erratic once a minute popping sound of cooling metal, rather a constant faint sound. Like someone continuously crumpling a ball of paper, or faintly boiling water on a stove.
So, could someone with a 95+ US model take a listen down there next time you park it? You have to get to it within a few seconds, and have your ears fairly close - couple inches at most (don't burn yourself). See if you hear this as well. Might be normal. I've got very good hearing, so maybe some of you young guys can hear it in the quiet of a garage?
Thanks!
DougM
Doug, in the hope it helps, I do not notice my cat making that sound. HTH :cheers:
Only thing I hear is a faint voice from inside the ps frame rail screaming to "let me out". I'm not going to though and will let the future owner deal with it.
Checked today and no such sound, just the expected popping sound of cooling metal. '97, 77k mi. Hope this isn't as serious as it sounds it might be.
Possible Help?
Doug,
I had this issue a few months ago and when I looked at it real close I realized that the rubber mounting points for the CAts were F-ed up. In other words one was completely torn off and the other partly loose and broken up. Made it sound as you are describing it and would knock if I punched the gas hard. Replaced the rubber mounts courtesy of my local Toyota dealer (or stealer) and fixed it. I hope this helps, the mounts are directly above the cat and pipes so you have to get under there. I have also heard of small rocks making there way into the cats all the way from the exhaust. Best of luck let us know what it is and what happens.
Sam
Doug;
Maybe a leak in heater system thats dripping on cats.
Let me clarify. You park the truck, SHUT IT OFF and then go listen. Sounds like I didn't make this clear - the engine is off and you can hear it after shutdown for a minute or so.
It's not a drip onto the cats as that would be a big hiss, then tail off every drop. This is a steady low boiling sound.
DougM
You guys have all ruined your hearing. I flagged down a new neighbor in their 40th a few minutes ago. They were intrigued and shut it down for a second in my driveway. I can clearly hear their catalytic converter doing the exact same sound as mine. You have to get down on all fours and put your ear within a couple inches.
So, no need to pursue this - I'm satisfied that my 97's cat sound is normal and not the sound of coolant from an internal leak.
Regards to those who checked.
DougM
