Anyone running OME 851 fronts with 862 rears? (1 Viewer)
Corrales, NM / Las Vegas, NV
I am currently running OME 861 and 862 springs with 10mm spacers all around. I would like to install an ARB front bumper and want to stay close in height to what I have now. Dont mind if its half inch taller. Wondering if 851s with no packers will net around the same lift with the bumper. My current measurements from center of hub to fender flare is about 21.2 inch on the fronts and about 21.5 inches at rear.
I could also do a 20mm packer up front and keep the 861s to compensate a little for the bumper. Just curious about the 851s with 862s
The 861 is a dual rate 170/250 coil. The 851 is a single rate 220 coil.
The 862 is a better coil.
Just put the bumper on then add a coil spacer the amount needed to get back to where you want.
