guerasfj60
if anyone is, please post the info
They don't come in a 16" but I do have them in a 17". Just installed them over the weekend and am very pleased with the outcome. Lift will be going on Wednesday. Running 305/65/17 AT's and they rub a tad bit in the front and back. I'm hoping the lift will alleviate the front. I am sure I will need to work on the rear for sure. View attachment 1884997
Nice choice.They don't come in a 16" but I do have them in a 17". Just installed them over the weekend and am very pleased with the outcome. Lift will be going on Wednesday. Running 305/65/17 AT's and they rub a tad bit in the front and back. I'm hoping the lift will alleviate the front. I am sure I will need to work on the rear for sure. View attachment 1884997
Which 305/65/17 tires are you running?I did't really take good photos of the wheels. But you can see the type of stance/poke that these 4.75 BS and 0 offset gives with a 305/65/17R tire.
View attachment 1886847View attachment 1886848View attachment 1886849
Thanks for the info. I've been looking at the MR 701s and trying to figure out which what tire to match up with it. Procomp's website has the tread width of your tires at 10.1" and the section width at 12.4". Did you have to make adjustments for any rubbing?
Your in the 100 series forum. Our trucks are 5x150 bolt pattern - so no 16” for us.They do come in a 16x8" wheel now with 0 offset and 4.5" back spacing, should be perfect for an 80 series but I have not determined the hub bore yet.701 | Method Bronze
The 701 Bead Grip® wheel was designed to be the perfect wheel for overland enthusiasts. The Bead Grip® technology allows deflation of tires down to pressures that previously would have required beadlock wheels to make sure tires didn’t debead. It’s advantageous to reduce tire inflation pressure...www.methodracewheels.com
Gotcha, but I had seen that the OP stated "or any 16" method wheel" above.Your in the 100 series forum. Our trucks are 5x150 bolt pattern - so no 16” for us.
View attachment 1886847 View attachment 1886848 View attachment 1886849
Do you like the 701s so far? Any issues or anything like that?
They have 18x9s that I want to pick up in matte black, that come in +25 offset...
Hey, what is the offset on these and can you post a side pic of the poke?They don't come in a 16" but I do have them in a 17". Just installed them over the weekend and am very pleased with the outcome. Lift will be going on Wednesday. Running 305/65/17 AT's and they rub a tad bit in the front and back. I'm hoping the lift will alleviate the front. I am sure I will need to work on the rear for sure. View attachment 1884997
