Ran on this setup for few months (wife was pregnant so I had to put off OME springs) - Not much different from stock shocks except the fact that those poly-utherane (sp?) bushings does not absorb road imperfections as well as stock rubber ones.
Thanks. I'm actually replacing both, springs and shocks, but am thinking about going the less expensive route and use OEM springs with OME shocks. I'm hoping to gain on the ride side of things by replacing the shocks with OME. Right now bumps are pretty jarring. I need to replace the springs to get rid of a slight drivers side lean. Sound like it'll work?
MoJ,
If you're replacing both, the best sequence is OME springs first, then the OME shocks. Work with the guys at Slee offroad to choose the springs that are right for you, your truck's load, and the terrain you drive.
-B-
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
