Anyone know anything about this Alternator???
the reason i went with this one was b/c it was 50amps instead of 40. I am having some issues running my lights, driving lights, heater and radio at the same time. It wasnt charging my battery fast enough....
Time for dual battery set up?
Just make sure you use a gauage cluster with a 50 amp gauge or you run the risk of frying it. :eek:
Just for a larger safety margin, I would also update the wiring from the alternator to the gauge and gauge to starter with wire one size larger than what is there now.
4alterstart.com has quite a few alternator options that may work for you, I don't know for sure what would fit your engine. Convert to a 1 wire GM? Mean Green $$$ With dual batteries?
Well, i just added Fuses so hopefully it wont toast my system.
What about Voltage regulator?? Will i need to change?
Adding fuses won't keep you from frying the amp gauge in the instrument panel. Run more current through that gauge than it is designed for will toast it. In the factory harness, all the draw from the battery goes through that gauge. I run a 200 amp alternator and had to bypassed that gauge with my new feed wire going straight to the fuse panel. If you are going for more current output than the harness was desighed for, then larger gauge wire is called for from the battery to the fuse panelat the very least. You should look at upgrading the primary wires in your harness to carry the load.
Yep. I have the entire front end harness off an FJ80. Main cowl, engine wire, transmission wire, and front engine wire. I will splice in my old haness where necessary but I will generally use this one in the front. I just need to change the connectors on it and remove some of the crap I don't need.
I even have some nifty stock toyota electronics boxes now (from the auto transmission relays that I don't need) to put my own electronics in. I plan on making an automatic tank switching unt for a dual tank setup.
Whoa.....
are you going to replace the wiring as advised?
Adding more current isn't a problem as long as that current does not flow through the guage. If all of the "stock" components run through the guage you will be fine. Just bypass the guage for current hungry add-ons (bright as the sun lights, 1000W stero, etc.). Just make you fuse them properly.
The subcircuits can only draw as much current as their resistance will allow. So just because the alternator and source the higher current does not mean that it will be used. Voltage is still regulated to the same value... V = IR. If you think it might be a problem you can put a simple MOSFET circuit in series with t he meter and bater to limit current in that circuit to 30A. It would be very simple to do.
I am assuming that the wiring is upgraded to hangle the current of course.
true.....i guess i will find out. If it sucks i'll send it back.
be careful - they might give you some trouble... a month ago i went to get an alternator from auto zone and originally i was going to just get a new one and see if that was the problem in my buddies truck which wouldn't start.. if it wasn't the problem i was going to bring it back.. but they told me if i installed it i couldn't return it... so check on their return policy before you go and install it to find out it doesn't make 50 amps... have them test it on their machine if you are worried and see what it makes...
all extra components added (Hellas, winch, amp) are a direct hook up and fused. Everything else will be going through the gauge. I had all my wiring updated from the firewall forward.....
if it blows up, i'll be sure to post pics.....:D
good advice....thanks.
