Anyone here have the hook-up for sheet aluminum?
Discussion in 'Chit-Chat' started by wngrog, Aug 5, 2005.
  1. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    I need a 4x8 sheet of 5052 T6 aluminum
    .060 to .090 thickness. Would rather have the .060
    Any leads?
  2. sleeoffroad
    sleeoffroad Supporting Vendor
    6,137
    977
    Mar 27, 2003
    Why? Need something to connect those two singlewides together in the new small town? Can't believe the Kate build has forced you to downsize and go live in the country :flipoff2:
  3. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    You are useless to me Slee....
  4. DSRTRDR
    DSRTRDR I can mangle anything ... SILVER Star
    14,255
    Media:
    42
    Albums:
    1
    1,466
    Jan 4, 2005
    Baton Rouge, LA and Fountain Hills, AZ
    would it be too serious to suggest you search the yellow pages for a sheet metal place in your town?
  5. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    Good question.
    Not many places deal in T6 hardness sheet aluminum and those that I usually deal with have earmarked all of their aluminum for the airline builders right now.
    No little guys....................
  6. Desertdave
    Desertdave
    201
    Apr 9, 2003
    San Jose CA
    Have they started using road signs in Texas? I hear those make good parts, as long as you don't get caught!
    Ahh, I doubt they are T6, though. Probably not worth the risk ;)
  7. PUPTLAM
    PUPTLAM
    414
    Media:
    18
    Albums:
    1
    2
    Jan 6, 2005
    EAST COAST
    what are you building out of t-6? thats some stout stuff and very brittle if you have to bend it.
  8. wob
    wob
    2,813
    686
    Feb 28, 2003
    SC
    I think you should contact one of the (many) aluminium boat builders in LA. Gator Trax, Gator Tail, and ProDrive. They could put you on the right track, and the fact that they are all Cajuns, usually willing to help you out. Gator Trax is in Springfield, the other two are in Loureville (sp?).
  9. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    I have been running a bent 1/2" T6 skidplate for 2 years and it has held up fantastic.
    The T6 is what Sunray builds all of their buggy floors out of. I am just trying to get what they usually use. I know crap about it all. Just doing what I am told :D
  10. scottm
    scottm
    3,168
    Media:
    8
    Albums:
    3
    3,692
    Mar 27, 2003
    Third Coast, USA
    Where are you? I can look around in the morning, but it wouldn't be worth looking if you're not around here. My shop uses a lot of 6061 T6 bar stock and extrusion, tool-and-jig (cast) plate, and soft-tempered sheet aluminum. I haven't seen hardened sheet aluminum, not real practical for our machine building. We shear and bend a lot of sheet, up to 1/4. I've tried bending the hardened bar stock with little success, it usually cracks. Maybe radiusing it would work? Are you making a whole belly pan from this? We usually get 4'x12' sheets.
  11. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    I am in Dallas. I need a full sheet.
    Making floor panels for my rig.
  12. PUPTLAM
    PUPTLAM
    414
    Media:
    18
    Albums:
    1
    2
    Jan 6, 2005
    EAST COAST
    just wondering? How will you attach it to the truck? You cant weld aluminum to steel. If you rivet it in I would put rubber between the aluminum and steel to prevent dis-similar or galvanic corrosion.
    Please post up some pictures of the finished project. My floor boards kinda suck. The P.O. fiberglassed them but its a band aid at best.
  13. RavenTai
    RavenTai
    6,048
    38
    Nov 16, 2003
    Dixie co. Florida
    You may have better luck finding 2024 T3 or 7075 T6, they are more commonly used in aircraft structure. They may be a more expensive though I don’t know how much. 7075 T6 would be the strongest common aluminum alloy. .063 will not take much weight on wide spans without support, I would not go past 20" in any direction, .071" or .080" might make a better choice for floor boards, with aluminum it is best to have many small fasteners, 3/16 or 5/32 fasteners on 1’ spacing should be good, in general 4 to 6 diameter center to center between fasteners, Maintain 2 faster diameters minimum from the center of the fastener to the edge of the sheet. To prevent corrosion Prime with a very thin layer of zinc chromate primer and paint before assembly, aluminum alloy is much more susceptible to corrosion that pure aluminum, especially at joints and any where moisture can sit. Usually better alloy sheet is clad with thin layer of pure aluminum to reduce corrosion. Assemble wet with a good strong sealant at all joints. 2 part Polysulfide would be best, Also install the fasters wet. Will help with corrosion and strengthen the joint.
    I don’t think I have ever worked with 5052 cant tell you much about it, the 5000 series is generally only used where welding of the part is required IIRC they are generally weak alloys, it may be used in automotive because of this and lower cost.
  14. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    I have used steel mounting tabs in the past with no problems. .060 steel tabs with 1/4" holes. We use stainless bolts with no barriers such as rubber.
    Raven, thanks for the tips. If I cannot get the 5052, I will grab some of the other you mentioned.
    Spans are not long, 10" max. We bead it and roll it to stiffen the aluminum without having to go to a larger thickness. .060 will be fine in my application. Trying to keep it as light as possible.
  15. scottm
    scottm
    3,168
    Media:
    8
    Albums:
    3
    3,692
    Mar 27, 2003
    Third Coast, USA
    We normally get our aluminum from Schupan, now bought by German owned http://www.copperandbrass.com. I don't see 5052-T6 in my catalog or handbook, but the -H tempered versions look good. -H34 is available, only a little weaker than the more brittle 6061-T6 we use a lot of. I did use some 3/16" 6061-T6 recently for a bent bracket. It bent well on the hydraulic bender, that doesn't bend as sharp a bend as the brake bender. Most of our thin aluminum is soft 3000-series, very workable but not as strong. You can get 7075-T6 in Alclad, it's quite hard and strong, but looks like it endures bending well. 2024-T3 is also strong and comes in Alclad, looks to be a little less bendable but still good. Dallas has to have aluminum suppliers, otherwise Schupan/Copper and Brass is in Houston and Austin, maybe they have trucks coming your way.
  16. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    Cool, I am not set on 5052 - T6 in the least, so if this looks like a good aluminum for what I am doing, I will pick some up.
    Thanks for your expertise!
  17. scottm
    scottm
    3,168
    Media:
    8
    Albums:
    3
    3,692
    Mar 27, 2003
    Third Coast, USA
    A distributor can give you much better advice on which aluminum than I can, good luck!
  18. wngrog
    wngrog SILVER Star
    25,445
    23,028
    Feb 10, 2002
    Canton, Mississippi
    You would be very surprised. When I tell them what I am doing with it, I get the dead silent pause........
    YOu have great knowledge, I appreciate it.
