Working on my axle swap and want to put in some caster correction bushings. Not having any success with using a close size socket Thought I’d check to see if anyone here has the tool. Thanks!
If no one has one Most shops will do that pretty cheap if you take the arms to them or take the arms to your closest dealership. They should be able to do them if you can't get the tool or buy the hole set from Joey. Bushing Press Tool- KITWorking on my axle swap and want to put in some caster correction bushings. Not having any success with using a close size socket Thought I’d check to see if anyone here has the tool. Thanks!
That kit is on my short list of tools to buy.If no one has one Most shops will do that pretty cheap if you take the arms to them or take the arms to your closest dealership. They should be able to do them if you can't get the tool or buy the hole set from Joey. Bushing Press Tool- KIT
It's on mine too. I need to replace my bushings badlyThat kit is on my short list of tools to buy.
That will be an iteresting 80 with two front axles under it! Maybe it will go fasterThanks guys! Axle is now positioned for install.View attachment 1577684
406 cruiser 80 owners split club tool
I'd be down for this. I will be switching to caster plates and stock bushings soon. Will likely get plates from wits end. Let me know.
