I’ve done most of the documented lighting upgrades in the center console, Hvac cluster, and instrument panel and I’m loving the results. I’m trying to get rid of as much of the green lighting as possible in favor of blue. I’d be real interested in doing the bulbs on the drivers door switches:
The photo looks much better than reality. These are extremely dim, the camera makes them look a lot brighter than they are.
I took the switch substantially apart yesterday, I got the plastic housing separated into several pieces without breaking anything, and got a look at the board.
That’s when I realized these are not lit from the board, there’s actually a bulb inside each little switch. So you wouldn’t need to pull the whole housing apart from below. You’d need to pry each switch out from above (minus the trim piece of course) to get inside. Wondering if anyone has attempted this? I’m not even positive the lights can be changed?
it would even better if the button are lit green because they use a green bulb making the switch to blue easy? Or are the lenses on the switches colored green?
thanks!
thanks!
