Has anyone ever had out of spec valve springs on a 2F cause them any issues?
I've measured the height of valve springs from 3 different 2Fs I've taken apart and none meet the FSM spec. All fail the height test, but certainly needed a valve spring compressor to remove. So they have plenty of spring left. None of these engines experienced valve float or diminished compression due to out of spec springs. I also don't see valve float really being an issue on an engine I'm not going to rev over 3K rpm. I have only measured the spring height, and don't have a tool to perform the spring strength test in the FSM.
I'm putting back together a 250k mile 2f out of a FJ60 that has already been rebuilt once. I have no record of when, but it was definitely rebuilt with oversize pistons. The pistons, cam, lifters, bearings, etc all look fine. My thoughts are that new valve springs may just put unnecessary wear on the old cam, and this old tractor motor is probably going to be just fine running the old springs. This engine had great compression test numbers before I pulled it apart to check everything.
