for your air compressor? if so post up what you did.
thought about that, and then also gluing egg-crate foam to the inside wall, and ceiling. also i would put a motorized louver system in so that it could cool properly.I've done a few soundproofed rooms for other applications - some of them being pretty high dollar projects. All depends on how much you want to pay.
A fairly cheap solution is to use a layer of Homasote against the studs before you put drywall over top of it. There are installation directions for walls and ceilings on that page.
i never have! but have worked on an tennant improvemnt project, where the owner wanted the bath room sound proofed. this was a large warehouse that we were building two flloors of offices at one end. the construction of the "sound proofed" walls were as follow.....from inside(bathroom) to outside (a hall way)- dry wall nailed to the inside of a wood framed wall(maybe it was screwed-whatever)...then 3" thick, mineral insulation in battons "LIGHTLY" placed between the studs of the two framed walls cross ways to the studs(no insulation wedged verticaly as you might assume..and no drywall inside)...then the framing for the outter wall and finally drywall faceing the hall. there had to be NO braceing,pipes, electrical conduits, etc. tieing the two framed walls to each other.(exception was the existing floor and the overhead. this allowed one wall to vibrate, but no vibrations were transmitted to the second. years later i saw the same basic construction on an condo project..the sound proofing was in the common walls between two tennants. only this time there was no insulation between the two metal studded walls.- take from this what you will
It is based on the fact that air will go around corners well, whereas sound doesn’t like to.
i have an 80 gallon 2stage, and yes it takes oil, i am planing on a motorized louver to the outside for air flow. and if it kicks on while you are in the garage, you can not have a conversation.
