Anyone else use OEM bushings on OME shocks?
Discussion in '80-Series Tech' started by hobbes, Jul 23, 2005.
  1. hobbes
    hobbes SILVER Star
    739
    207
    Feb 2, 2002
    Naples, FL
    sjcruiser mentioned in an earlier thread that he had favorable ride results by using OEM bushings on OME shocks since the rubber was softer. I'm putting a bunch of highway miles on the cruiser and have gotten a couple complaints with the current OME ride. Has anyone else tried this setup, and can you order the bushings alone if you already tossed the OEMs?
    https://forum.ih8mud.com/showthread.php?t=38771&highlight=shock+oem
  2. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    You can order them individually, just give C-Dan a call, that's who I just ordered a set from, saved me about $10 a bushing.
    I threw my OEM bushings out :whoops: when I installed my OME bushings. Unfortunately, they didn't provide enough caster correction so I decided to order Slee's caster plates which require OEM bushings.
  3. drexx
    drexx
    540
    8
    Sep 8, 2003
    24Jul2005 (UTC +8)
    Q: Anyone else use OEM bushings on OME shocks?
    A: I do! I first learned of that trick from Mr. Slee back in y2002.
  4. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    Me too, kinda. I have the Edlebrock ISA shocks and they are great but alittle short...about the same length as Bilsteins(extra info). Anyway they came with rubber bushings like the stock OEMs. However a shock on my rear began to leak and I sent both rears in for replacement (Lifetime unlike the 2 year OME). The new ones now come with poly bushings like OME and WOW I could tell a big difference. So I put the old rubber bushings I kept back on and I like it this way much better.
