I have searched and am not finding a thread that discusses this. I need one as I'm about
to iteratively flip over the tub for blasting, final sheet metal work, and painting. Its an odd
body configuration with no clear mounting points on front and back....thus I'm thinking of
building a wood frame under it that I then attach my front and rear plywood radius'. But
even that is weird because (at level) the rear is 8 inches higher than the front mounting holes
and I'm concerned about center of gravity.
Anyway...my first thought is two "rails" made out of 4x4s that are 9' long. I then attach
1 (2x6) at front mounting position.... 2 (2x6) at mid mounting position and then ??? at
rear to sit on the rails.. That seems screwed up as I'm dealing with too much lumber
in the rear for bolts to clear...so I think I'll skip the mid mount and just double up (2 * 2x6") on both
front and back tub mounting points (damn the mis-level).
Anyway ... ideas or previous experience is appreciated. I definitely want to keep it simple
but useable for quite a few tip overs.
