Can someone educate me so I can understand whether I should be concerned? I just had the windshield replaced in a 100 series. I note that the rubber weatherstrip at the bottom of the glass is raised up about 2-3 mm from the glass surface for about 6 inches at the middle of the windshield. It is attached to the cowl piece but the cowl seems to be lipped up a little in the middle where the two portions meet and is holding the weatherstrip above the glass.
My question is this: I know the cowl itself has vent louvers and allows water to enter into that space, so does the water that is going to flow under the weatherstrip end up in the same place and just get drained out?
The windshield guy said not to worry about it and that it might "settle down" when the weather warms up. He said he prefers not to glue it down cause it will then be a problem when I get my next windshield.
My concern is that it is right behind the nav system, etc and I imagine water will run down the windshield and preferentially into that space.
Any comments are most welcome.
Thanks.
Thanks.
