Any visual difference between 305 & 350
Pulled the motor out of a 79 Chevy 2wd. Not sure if it is a 305 or 350. Does anyone know an easy way to tell? Getting it ready to rebuild and stick in the cruiser. Thanks.
There are two numbers. One tells some info the other tells all the info. The casting number is cast into the side of the block. I have seen that number not tell you the final displacement of the motor though. The stamped number that lives on a protrusion on the right (passenger's) front just below the head will tell you everything. With those two numbers you can tell the displacement, day, week, year and shift it was made, the type of car it was installed in, the h.p. range and the transmission. There are a number of web sites that have this info, but there is one outstanding one. I'll google it and get back with it. It's a link Woody oughtta have if he doesn't already.
AFAIK, there is no other sure way to tell besides measuring the bore or stroke.
I thought that the harmonic was thicker on a 305.
I could be wrong.
someone know?
an easy way to tell the difference between the 305 and 350 is if you look at the push rods the 305 have 6 inch push rods and the 350 have 8 inch push rods if i remember right all i know is the 305 push rods are shorter than 350 push rods
Gumby, I can't get the link to work.
Don
I used Google to search for "Chevy small block casting numbers" and found more than 44k results.
From one of the sites:
"The Engine Block Casting code is one of the best ways to identify a Chevy engine block. This Casting number is usually found at the rear of the block on the left or drivers side on top of the bellhousing flange. "
My 305 has a "5.0" cast into this location.
You can also search on the exact casting code that you find there if unsure.
This would be complete BS... There's no way in he!! there is a 2 INCH difference in a SBC pushrod.
Nick
