Any reason CEL would come on after...
S. Texas
Any reason CEL would come on after... Found the problem
Decided to change transmission, diffs and transfer case fluids today. Just drained the trans and re-filled with 6 quarts. Drained the other three and re-filled. While I was down there decided to change out speedo gear I've had for two years. Replaced w/ no problems. Warmed up engine, went thru the gears several times - trans fluid level - a little above normal. Went to Lowe's and on the way home CEL light came on. Any ideas? Does the computer have to be reset when changing speedo gears? I currently have 134,000 mi. I'll try and run it by Auto Zone tomorrow. Nelson
Thanks to those that answered. There is a little "pin/key" that came out with the old gear - didn't install with the new. Should have paid more attention. Nelson
NorCalDoug
problems solved daily...
uhhhh...duh...Northern CA
My trans drain/refill works out to 4 quarts. I wouldn't think too much tranny fluid would spark a MIL coming on. Never heard of the speedo gear doing that either.
Texas
Pull the code or have it pulled at Autozone for free...this will tell you.
My bet is on..."coinsidence".
