Any F155 Engine build part numbers for early FJ? Build tips/comments? Perf parts?
Norfolk United Kingdom
I will be getting to my engine some time soon so I thought I'd do this post
My philosophy is build for reliability and longevity first, increased torque, and maybe do some fun things that are not too expensive perf wise
here are some ideas
Engine rebuild kit-top and bottom rings bearings etc
full gasket kit
replace freeze plugs
hardened valve seats
nitrided valves if available for FJ
intake man/head/gasket matching
bead blasted and magna fluxed rods
forged pistons
smooth out casting bumps etc in manifold
electronic ignition
heavy duty alternator
shave head or domed pistons for a reasonable increase in compression but not too high
rv Torquer cam---P/N recommendations?
standard exhaust for compatability with pto winch but hi flow muffler as quiet as possible for good perf--Thrush?
maybe balanced probably not bluprinted
Any tips comments or part numbers that we can refer to later?
This is a 71 FJ with the original motor
any links with part numbers I can copy to here?
I searched on engine build part numbers and didn't come up with much, anyway as I find p/ns I'll post them here
could be handy
head
Yeah I never mentioned that, for what I'm shooting for I would probably would just smooth it out but not polish.
Ive done a little googling and there seems to be a lot more on rebuild kits for the 2F
I need to get an eng FSM and see if there is an OEM p/n for a rebuild kit
Thanks for the suggestion
1.5 base
I need to do some more reading on that I've seen some stuff about the oil having two paths through the motor on the f eng but all thru the filter on the 2f.
I'm not looking so much for all out perf as much as making the best of what I have. But is the F motor not worth the rebuild it has 136000 on it now I wouldn't feel too bad to see it do that again, that would probably be 10 or 15 years down the road.
Is a 1.5 or 2f worth the extra expense?
