Any easy way to mount a 60" Hi-Lift on the stock rear bumper? (1 Viewer)
Don't have a real rear bumper and my hi-lift is going to have to live in the truck unless I can figure out a way to stick it to the rear bumper. I'd rather not mount it on the front bumper (ARB). Any suggestions?
Something like this through the bumper
Is the stock cross member wide enough to hold a 60" hi lift securely with only those bolts?
I used a hex coupling that fit perfectly in the slots of the Hi-Lift and then found a knob with a threaded make stud to go into the coupling. A large rubber washer on each side provided some cushion. I'm sure you could adapt to fit your bumper.
