has anyone on here done it? ive heard they work well and dond bind up your flex, anyone on here have one?
antirock sway bar?
Is that a sway bar that's not just a sway bar?
Or a sway bar that's not a sway bar at all?
Or a sway bar that repels rocks?
Not quite sure what you're talking about other than something different than the stock sway bars...?
They originally designed it to simply keep the body of the jeep as level as possible.
Thats what i'm after, they come with universal weld on mounts, so i could put it under the frame
It's a good approach to bring these tried and true designs from the Jeep world over to your 80 - I'd definitely be looking into it if I had your design goals. Keep us posted.
That was my point. When Currie says "Keep the body of the Jeep as level as possible" I do not believe they were talking about road use. And the anti-rock swaybar cannot do this without interacting with the suspension.
So will it also "keep the body of the 80 as level as possible" independent of the suspension you bolt onto your 80? Good question, bad assumption.
I had this though awhile back since no one has quick disconnect sway bars for 80s, glad someones going to do leg work!
