Well I finally got around to fixing my antennae (97 fzj80) and I thought I would share some pics and a few tips from my install. I have gotten alot of good info from this board in the past so I thought I would share.
Syptoms> My antennae stopped going up but I could hear the motor running so I assumed (correctly) that the antennae cord broke (which it did).
Start by removing the retainer nut on the fender. I used a pair of snap ring pliers reversed to grip the slots on the retainer nut. Worked pretty good. Once that was off I was able to pull my antennae out. I would think that you would have to get it out at this point, if you can't pull yours out you might be able to if you run the "up" button to aid in the removal. After the antennae came out I pulled the rubber grommet off as well.
Next I popped the hood. I had to remove the grey box pictured below to gain a little more access to the hole that the antennae motor is in. 12mm socket and it came right out. No nut to worry about.
Next took an 11mm to remove the one bolt that holds the antennae motor in. I held onto the motor while I did this. When this bolt comes out the motor is free to fall into the fender well, but don't worry, it's easy to reach. Once it's loose it takes a little work to turn it upside down and over so your bringing the motor out first. The mounting bracket will give you a little trouble but it will come out. Once you work it out of the fenderwell you will have just enough slack in the wire that goes to the stereo to pull it out far enough to take it apart. There are 6 screws to remove. 4 around the edge, 1 that has a wire on it (think it's a ground) and one in the center. NOTE: The one in the center has a nut that will fall out, it's accessible from the back of the motor.
Once you get all the screws out, open it up. I didn't have to disconnect anymore wires or cut the original wire wraps to do this. It's sealed with some black goop so the lid will not just pop open. Once open you will see this:
The large ring is where the cable stores when the antennae is retracted. This is where I found the rest of my wire. Lifted the ring out and took the remains out. I didn't have any more pieces, but make sure. Lift the inner gears out and look for more pieces...it lifts right out.
Time to reassemble. Put everything back and button it up. The center screw with the nut is the biggest pain in the ass part (not that bad). The nut drops in the backside, when seated right, it will hold itself in place so you can screw it back in the other side without using a socket. I used a screwdriver to hold the nut in until I could get the screw threaded in. Tighten everything up. Wedge the hole assembly back in the fender well and remount everything.
You will need another person for this part. My 10 year old daughter was very helpful here. Put the rubber grommet back in the hole, PUT THE RETAINER RING ON YOUR NEW ANTENNAE BEFORE INSTALL. Make sure it's on the right way (up from the cord end, threads down). Turn on stereo and run antennae all the way up. Put antennae cord in until it stops THREADS TOWARDS REAR OF VEHICLE and run the antennae button down while feeding cable in. Mine got about 3 inches from all the way in. I stuffed the antennae in the hole and hand tightened the retainer ring. Run antenna back up, then turn the stereo off. Should thread all the way back down now. Turn stereo back on and make sure everything works. I didn't have any problems. Tighten retainer ring and your done.
Tell wife what you did...BE A BIG HERO!
Over all took me an hour it's a job.
Remains of my antennae
Part number
Good luck, hope this helps
Scott
Part number
Scott
