I got around last night to doing my antenna replacement. The PO had installed a cheap fixed antenna (no adjustment) that was crooked, bent, wobbly and would not tighten:
So I ordered a Toyota factory replacement from Onur and installed it last night:
As with any LC project there were complications. The POS installed by the PO was frozen together and had bent the edges of the antenna hole, so it took a while to remove and I had to do a little remedial work:
The factory antenna is superior to any aftermarket because it comes with a brace that bolts the bottom of the antenna to the fender. It is rock solid once it's on. If you need a new antenna this is the way to go.
