It was a major pain removing the cheap antenna the PO installed...of course another simple job becomes a pain. It stuck up 6” when folded down and was starting to rust so I’m swapping it for an OEM manual antenna.
I expected to see an unplugged harness for the original stock power antenna but found much more. I came across some wiring the isn’t stock and looks to be remnants of something no longer in use. Also, a box (maybe a relay?) with spade connectors.
Is this related to the modern Pioneer Bluetooth headunit? I don’t think it’s stock but maybe it’s spliced into something.
The only thing I disconnected was the antenna input BUT now my dome light flickers for some reason....UGH.
The truck started fine and the modern Pioneer Bluetooth headunit powered on fine. I didn’t test it further tough.
I need to pull up the wiring diagrams. Any thoughts?
my initial thought is wtf.
