Hi I am new to this forum:
I own a 1984 FJ 60 with 200,000 and have had a heck of a time trying to figure out the cause of the OH(overheating) . Specifically, the truck runs at normal temp when driving around town and on the highway in cooler temps. Running on the highway in very hot temp causes the gage to go to 3/4 mark especailly after long rides. (two hours). The problem though is after running on a highway and then stopping like in traffic or at the exit offramp my guage climbs to the very top near the red zone. I have to put the heater on to pull the heat off. I also noticed that if i keep the engine revved, the temp gage drops down. The mech checked my block-no cracks, temp at idle is normal, cored the radiator, new water pump(aftermarket pump). He took out the thermostat?(should this be out) fan clutch is supposedly ok? Pressure tested system and is ok. Hoses fairly new? I also noticed water running under the dash after turning on the heater. Does anyone know what this good be?
Thanks for your advise
Nancy
1984 FG 60 4in lift
lowered gears 4.92
Nancy
1984 FG 60 4in lift
lowered gears 4.92
