Sorry, trying not to beat a dead horse. Just when i thought all was clear about pinion angles, drive shafts, U-joints, i go and read on slee's sight about the adjustable control arms. Slee states:
"When the rear suspension if lifted, the axle will rotate backwards thus forcing the pinion of the differential to point upwards. The result is that the pinion angle of the rear differential and the flange on the transfer case are not parallel anymore. This can introduce vibrations in the drive train. By making the upper rear control arms adjustable, one can rotate the pinion angle down and correct the angles, thus eliminate vibrations. "
I would think that if the two were parallel, then that would be a much greater angle on the ujoints; where as if the pinion was pointing at the tcase then there wouldn't be much angle on the U-joints thus less grrrrr and wearing out of ujoints. what the heck, i'm confused again?
