Another new 80 owner (several questions)
Been lurkin here for a while, just bought a 94 80. It is nothing really special, non-locked, no CDL button. It has almost 200K on the clock. This site is awesome! Have a few questions:
1.) It does not have the CDL button. When I shift to LO range isn't there a light that is suppose to come on on the dash and lock the CD? It goes into LO fine, but no light at all on dash.
2.) It has green AF. I plan to have it flushed, should I switch back to red??
3.) This will be our DD for a while. I want to make it as reliable as possible (no mods yet). What are some of the common problems that can put you on the side of the road on a high mileage 80? Should I go ahead and replace the fuel pump, water pump, alternator, starter, belts, hoses, etc.??
4.) I plan on running Mobil 1. Is 15w50 too thick?? Should I stay /10w30 high mileage??
5.) I don;t know when the trans fluid was last changed. I have to change it though. Iunderstand there is no filter, where is the screen that I need to clean?? Is it right above the pan when I drop it?
Sorry for so many questions. I have alot more, but these will keep me busy for awhile.
Any help would be greatly appreciated!
Does your ABS light come on?
Welcome. The FAQ is your friend for most of your ?'s.
1) Bump it hard into 4Lo or put it in 4Lo and push the Cruiser up aginst a low wall or stump and hit the gas a few times. That's what freed up mine.
2)I would
3)Headgasket issues and birfields seem to be the only major items that come to mind.
4)I would stick with 10W30 high mileage and watch your oil pressure.
5)Not sure. If the trans fluild doesn't smell burnt or isn't a dark brown I wouldn't worry about it.
TK
welcome!
1) You should be able to feel whether the center diff's locking or not; you need to figure out whether it's an actuator issue or just a light issue.
2) I wouldn't.
3) :meh:
4) LOTS of oil brand/weight recommendations; look around.
5) Yes, screen is just above the pan. Definitely clean it and change the fluid; great way to get quick information about the condition of the tranny.
Welcome,
Curtis
91FJ80, 243K
Search for PHH. I did mine at 90k miles and it didn't look good. That will put you on the side of the road in a heartbeat. Use 1FZFEPHH in the vendors list, they're great.
Welcome! :flipoff2: Color? Pictures?
Welcome to Mud and the addiction!
On the issue with your CDL; when I got my 80, neither the CDL or ABS light would light when in 4-low. I took it to a gravel lot, shifted into 4-low, and drove in a cirlce. The CDL was defintely locked, as the truck will buck, and fight turning in a circle. Once I knew for certian that the center diff was actuating, I checked the CDL indicator switch that is located on top of the transfer case adjacent to the CDL actuator. I found that one of the leads coming out of the indicator was missing. I replaced this indicator (Thanks Cdan) and everything works great.
:cheers:
Do all 94s have ABS? My ABS light doesn't come on but the CDL does.
Since you are already Green, I would just stick with Green.
Welcome,
As you said, this site is great. I have baselined my 94, replaced my fan clutch, modified the temp gauge, serviced the birfs, adjusted the e-brake, fixed my shakey drivers mirror and several other things. After searching this site I found I had very few questions for the MUD members ;). It's all been covered. Good luck :cool:.
You tell us: Surely you can figure out whether or not you have an Anti-lock Brake System? :confused:
Note: If you have rear discs rather than drums, pretty much guaranteed you have ABS. I have heard of some early 93's with rear drums, semi-floating axle, and no ABS.
Well I have only owned my 80 for a few weeks and the ABS light has never come on that I can remember and when braking on ice, I don't hear the clicking you would normally associate with ABS. I do have rear discs though so I must have ABS according to what you say.
well, just got an 80 last week 94 not locked, first prob was power stering pump leaking, thanks to ROMER i will rebuild it tomarrow, let you know how it goes, other than that no power spray on the windows, im working on that also, congrats, wheres the pics son
I really appreciate all the replies! Took it out again today and shifted hard into 4lo, no lights at all came on, no ABS or CDL. I drove in a figure 8 and I'm almost certain the CD is not locked (no bucking). I do hear a clicking coming from the dash area every time I shift, but that's it.
My wife sold her vehicle, so we need to start using the LC as a DD asap. I need it reliable now, so, as much as I hate to, I think I am going to take it to the local dealership to rr/pm the HG and PHH, service the front axle/birfields, replace all belts and hoses. Should I ask them to swap sides with the birfields? I usually like to do my on wrenching (most experience is with bowties) but we need to be driving it now and it seems like the most important baseline stuff is major time/labor intensive.
If I get the dealership to check the CDL what will they most likely want to do or say if it is frozen up because of lack of use??
I think I will stay with green AF. Is Toyota putting green in all their new vehicles now?
Thanks again for all the quick replies!
Welcome!:flipoff2:
