One more cosideration I haven't seen addressed: when was your last compression test and what were the results? Maybe you are down on a couple cylinders when cold. Just a thought.
B
x3 Bad news but thats the way I see it too.
B
Hi guys,
Wow I get busy for a day and look at the all the new ideas. Thanks,
So here it goes, I tried (for the hell of it and since it was a quick test) to unplug the water temp sensor before starting. Now the weather is not bad here, +5C, and I still had issues, the glow time for the primary relay was a bit longer then usual but nothing special. When I turned over the engine it had little issues with running smooth. I have to be honest, I have not done a compression check. For this I will have to either go to a mechanic or just buy the tester myself since I don't have one. I have been meaning to do that. I did notice that my priming pump is wet, there seems to be fuel leaking through that seal, but this is new and the problem has been evident since day 1 after I bought the truck. I am going to replace the fuel hose with something that will allow me to see the fuel level and see if there is an air/fuel leak that is actually causing this. Although in more cold environments (-10C and below) I have noticed that there is a significant amount of black smoke at start up, so fuel delivery does not seem to be the problem. Regardless I will check and let you know what happens.
As for rebuilding the injector pump, I will leave that option as a last resort if all else fails, but thanks for the suggestions guys.
